Please help solve a difference of opinion between several inspectors and electricians. We have 10 condos served on each end with a 5 gang meter center. Each unit is supplied with its own copper water line in direct contact with the earth more than 10'. Should you run the grounding electrode conductor from each service to one water line sized on 250.66 and the total circular mil area of all of the feeder conductors (underground service utility supplies service lateral) and bond each water line in each units sub panel or run one grounding electrode conductor sized for each feeder to each water main in each unit back to the service and not bond in the sub panels. Thanks for any help
