R Rick Headlee Member Location London Ohio Apr 23, 2007 #1 I am looking for a load calculation for a 4 unit apartment building. Do I use standard residential calc or another method. Thanks Rick
charlie b Moderator Staff member Location Lockport, IL Occupation Retired Electrical Engineer Apr 23, 2007 #2 I would suggest trying both the standard method and the optional method. You get to use whichever one gives the lower results. I suspect that will wind up being the optional method, based on the examples and test questions I have seen.
N necnotevenclose Senior Member Apr 23, 2007 #3 Rick, Check your local code amendments they may have restrictions for the optional method.
R RRelec Member Location Florida Keys Apr 24, 2007 #4 Standard or Optional? Standard or Optional? You have to do the standard anyway, then you can chose! R
