randy263
- Los Angeles, California
I'm looking at upgrading an old 4 floor building, where the upgrade will mean virtually installing all new service and feeders to each floor. Each floor will be used for different purposes, and those purposes have not yet been fully defined. But as a rough estimate, 200A per floor seems reasonable starting place.
So my question is: Is it better to run home run 200A feeders to each floor with a 200A disconnect for each at the first floor (and an 800A main), or to run a single 800A feeder to the top and tap at each floor with a 200A subpanel/OCD? (or a hybrid, say two 400A feeders)?
The tap seems flexible for future. I'm not sure which is most economical. If a tap is used, can the tap be done with split-bolt connectors in a box at each floor or are lugs required?
