Multi GFI wet location woes
danickstr
Anyone have a good idea about using 3 gfi-controlled outlets in an area the is pummeled by sprinklers? Seems like there is usually a plug in use, and the various types of covers I have tried seem to let in enough water to blow the system often.
What is the best cover by experience? Also, is there a more durable bell box that is not aluminum that turns to bauxite in 3 years?
Just use an in use weatherproof cover and silicone around the perimeter.
In your situation, I think I'd use the Midwest box. That's about the only thing that's completely integrated that will exclude the water the way you need it to. They're right around 40 dollars.
http://www.midwestelectric.com/product/tppo.htm
If a more durable bell box is what you want, use a PVC FSE box. That's what I typically use in harsh areas like barns.
