malachi constant
- Minneapolis
I am an engineering going through Owner's requirements while writing specs. This one doesn't sound reasonable to me: "The use of multi-wire branch circuits with a common neutral feeding loads is not permitted." This is a standard educational facility, nothing unique about it.
The way I read this, every circuit shall have its own neutral pulled. Typically the contractor would pull a neutral for every three circuits (in a 3ph system), correct? Am I reading this wrong?
Unless someone can explain to me why this is a reasonable installation I'm going to ask the Owner for a variance from their standards. Thanks.
