Re: Multi-wire Homerun in the Kitchen(SA)
JPG,
A 2 pole breaker is not the way to go here. That rule applies only if the 2 phases are attached to a device on the same yoke (i.e a receptacle with the jumper clip snapped off). However, you should install 2 separate 20 amp breakers (one above the other) so that they are on different phases. That way you won't overload the neutral.
