aaSpencer
- south jersey
Thank you for allowing me to post here.
There is an existing apartment in which, each unit don't have its own electrical meter. thus the tenants pay by the 'averaged out' usage of the entire building.
The apartment has 8 floors with 10 units on each floor (thus 80 tenants).
The contractor has started working on this, and so this is the present condition:
For each floor, there is one - 42 space 400 amp panelboard in the electrical room to feed 3 appliances individually into each unit - 1 microwave oven, 1 food disposal and 1 dishwasher. Thus the panelboard uses up 30 spaces.
They used a 'feed-through' panel from the first to 8th floor (like 8 loads in parallel if that makes sense) and the conductor size used along the feed through is 250 kcmil from first to 8th floor.
The only thing they didn't do is to connect from the first floor panel to a 250 amp breaker in the MDP located in the basement.
The question is, how do we calculate the load with this set up?
This building was built in early 70s and have been in renovation for the last 3 years. I have been searching for answer but there is no crystal clear answer i can find.
By the way, some of the existing loads like the each A/C units are also tied up this way
Thanks for all the input and I hope I was able to make it clear enough.
AA
AA
