lagaceelectric
- CT
I have a condo building I am doing that has a modular 6 gang meter socket each with a 100 amp disconnect then i will be running #2 SER to each sub panel in the individual units. My Question is what size water bond wire must i run to the water main which is at the other end of the building? Then can i just jump to the sprinkler main with the same wire?. Also I believe that i only have to use #6 for the gas bond and also #6 for the ground rods. We are still on the 2005 code here in CT
TIA for any clarification.
Scott
Scott
