davidgarrett
- Greenville, SC
I need to buy a new multimeter. I do primarily residential and small commercial service calls. I would like to keep it under $150. Does anyone have any suggestions?
Are you looking to be able to take current readings with a clamp as well? If you're only going to have one meter, I'd look at a clamp meter.
The brands I'd look at first are AEMC, Agilent, Fluke and Hioki. Those are companies that design and manufacture their own stuff. They're also going to have the most expensive options, but I know Agilent (and sometimes AEMC, on their website) have some sub $150 choices with CAT IV and TRMS.
Next would be Ideal, Greenlee, Amprobe, Megger and Klein. They've got a lot of weight behind their brands, even if they're not designing and manufacturing themselves. I included Megger because I'm not sure they design or manufacture their clamp meters or DMMs. I think Ideal is probably the most solid of the bunch based on the clamps I've used or owned from these companies.
You learn something everyday ... I didn't know that Agilent sold meters mere mortals could afford.
More info from Fluke on Ghost Voltage (AKA Phantom Voltage, AKA Stray Voltage):
http://www.fluke.com/fluke/usen/community/fluke-news-plus/ArticleCategories/DMMs/Stray+Voltage.htm
Stray Voltage Elminator Link:
http://www.flukeonlinestore.com/3100477.html
Used on a meter like a Fluke 87V.
Many "Electrician" oriented clamp meters on VAC range have lower input impedance than a high accuracy DMM like a Fluke 87V. This helps to addess Ghost Voltage. I have a Fluke 381 and I have never seen it Ghost (480 VAC and less).
http://www.milwaukeetool.com/instruments/fork-meters/2205-20
I have several meters. After buying the Milwaukee one, my quest has ended. It's my daily carry.
