Don Warneke
New member
I am getting conflicting requests from inspectors. I have always run ground wires from each ground rod back to the panel for the grounding system, and never had an issue with the inspections. Now I have an inspector that is requiring a wire to run from the first ground rod, to the second, then back to the panel. Which is correct?
