jdping2
- Monterey ca
I have 10 - 240 volt single phase kilns, each kiln draws 48 amps at 240 volt single phase . I need to size the panelboard which will be serving these kilns, I have unlimited power available in the main switchboard. Question- not considering space for future expansion, what is the minimum sized 120/240 Delta 3 phase panelboard amperage that I can use to feeed the 10 single phase 60 amp breakers ( kilns are 48 amp ea) . I cant find reference in the code book for kilns , so I am assuming these need to be calculated as continuous load, and yes, the end user will have all 10 kilns fired simultaneously Thank you!!
John D. Monterey ca
John D. Monterey ca
