sgroff
New member
- albany new york
Having a facility with 42 motors started by vfd's and the vfd is controlled by a plc via dry contact for fwd or rev on the vfd. normally on a motor starter situation the control voltage for the coils could all be the same and run through the emergency stop circuit via a master control relay or contactor, meeting osha requirements as well. proposed way to meet requirements for emergency stop situation to shut off the run command for the vfd's? can't rely on the plc to shutoff those run commands.
