A Alwayslearningelec Senior Member Location NJ Occupation Estimator Dec 28, 2019 #1 So in this instance you would have to run 6 separate switch legs from the dimmer to the occ sensor( well really the power pack). Correct? Thanks Attachments Capture.JPG 95.1 KB · Views: 17
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician Dec 28, 2019 #2 What is the design function of the system are they using the sensor for normal lighting control of 6 different lighting zones or an override to turn everything on at once?
480sparky Senior Member Location Iowegia Dec 28, 2019 #3 Or are they calling out on the plans to see Notes r, s, u, v, w and z?
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician Dec 28, 2019 #4 The way it's drawn is does seem like the sensor is controlling multiple switch legs.
A Alwayslearningelec Senior Member Location NJ Occupation Estimator Dec 28, 2019 #5 Yes different lights have different switch leg letters....either r,s,u,v,w or z....as you can partially see.
