boolholt said:True...Would there be a limit as to how many splits you can wire on a single circuit?
I won't open this debate again. But I will just mention that not everyone agrees that that limit exists.stickboy1375 said:Not in residential.... But in the commercial world it would be 180va per strap.
In a nutshell, the argument is that the 180VA/outlet is for load calcs, and not binding on actual installation.Jim W in Tampa said:Open it i wanta hear this one .
alfiesauce said:Back in the day split receptacles were the norm in kitchen circuits.
alfiesauce said:.....At minimum take 2 split circuits up to two receptacles, and then no two receptacles next to one another could be on the same set. ......
480sparky said:I tried that once. Ended up backfiring on me. Seems the lady would plug in to every other outlet.....![]()
MF Dagger said:Did she actually start tripping the breakers? Thinking back I can't remember ever tripping any breakers in my house. The microwave went bad once and that tripped the breaker a time or two before I was home to see it happen. It surprises me too since my kid can manage to have every electrical device in the entire house turned on within about 3 minutes of waking up or getting home from school.
alfiesauce said:and thus you were the unlucky man of the day. sucks when thoughtfulness bites you in the butt.
Then that would be a 21 - 42 pole breaker - or one really long possible double acting handle-tie.....boolholt said:True...Would there be a limit as to how many splits you can wire on a single circuit?
