If you had multiple substations single ended with a single ended sparing substation and the substations had ground fault mains with the neutral/ground bond at the xfmr withtin the sub how would you prevent a main on one substation from tripping under a ground fault? For example if a fault occurs on substation #2 what is to prevent it from taking out the GFI on the main circuit breaker in substation #1 because all the grounds are connected to the new building ground mat therefore the substations are on the same ground? Could you do this throught some kind of protective relaying?? Just curious?
