steve holt
- Hawaii
Are there any code guidelines regarding having multiple switches on a single load? I have a single exhaust fan controlled by more than one single pole switch. The owner does not want to use 3-way switches because they will end up being in the up/on position even when they are off, and you may not be able to tell if the fan is running. If we go with single pole switches, then the return on both switches will be live when either of them are on.
