I have a client that wants power to at least 3 trailers(think old Airstreams). Most are gutted with remnants of DIY electrical systems inside. I have agreed to supply power to a receptacle outside the units but not go further than that.
My question is about ground rods. Does a 1-pole 30amp circuit feeding a 30amp receptacle need a ground rods driven? It doesn't seem like the panel in the trailer would have a GES because theoretically they can move, so you'd have to detach it each time.
Would the answer change with a 4-wire feed for 240v? Thanks for the help
