So I have an area in our shop that will be having a couple of trnasformers installed. They are all close in proximity. If I were to drive a ground rod for each one they would be too close (the rods) to each other.
Can I drive one rod for multiple transformers ?
These are all being fed from the same 480 panel
480 delta to 240 delta 3 phase
we may use a 120v LT (x4) from one of the transofrmers. Will this cause any issues when I bond the neutral and ground
The transformers sizes are
30 KVA
30 KVA
75 KVA
Thanks
Mike
30 KVA
30 KVA
75 KVA
Thanks
Mike
