Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
I wrote a post earlier regarding a 4800 p to 480 secondary delta ungrounded system transformer being pad mounted with only case or transformer cabinet being grounded but not secondary windings (ungrounded system by owners choice)
If feeding a second transformer to a building from this first (ungrounded) transformer to obtain a 2 phase 120/240 sub-panel how would this be done if second transformer is grounded at its secondary system windings and bonded to second transformer case as well as derived neutral (y system?) for line to neutral loads and to obtain a ground fault circuit path?
Is this feasible to have the first transformer ungrounded but second transformer system grounded at its system secondary windings, neutral, main bonding jumper etc?
First transformer powers only 3 phase motors and control circuits at a mine
Thanks
Thanks
