Question, I understand that when using regular THHN it is highly advisable not to install output wiring from different VFDs in the same conduit. But what if you use Belden cable specifically for VFDs? (Belden #29502 and above). I see on this forum that having multiple VFD output wires in the same conduit can cause voltage spikes, but isn't VFD cable supposed to alleviate this? We use RMC here at my plant (mostly aluminum but some galvanized). Thanks
