bigduvid
- Cleveland, Ohio USA
Subject: Multiplexed [Tri & Quad] Overhead Service & Secondary Cables.
Is there any code restriction of using Multiplexed Overhead Cables for feeding a garage from the house or between any two structures as a feeder to a sub panel or dedicated equipment use?
Multiplexed Overhead Cables is not listed in the NEC. There is no UL standard for Overhead Service and Secondary Cables. They meet or exceed the requirements ANSI/ICEA S-76-474. The standard includes sunlight resistant requirements. The standard does not require the conductors or cable to be marked sunlight resistant.
