Multiwire Branch Circuit
mkgrady
Massachusetts
I have a customer that needs more power at a pool shed. Currently they have one 20 amp gfci protected circuit that powers a filter pump and a convenience outlet. The breaker is located at the main house panel. wiring is through buried conduit. They want to add a propane pool heater that draws 5.5 amps. The pump fla is 15. The existing circuit is too small to power both heater and pump. If I convert the circuit to 120/240, 20 amps and protect it with a two pole gfci breaker do I have a problem powering each appliance with 120? I know it will work if I feed each appliance with 240 but I need to keep the convenience outlet working. I’m thinking it will work without tripping the gfi breaker. Am I correct? I want to avoid having to add ground rods which is why I want to keep it to one circuit.
A two pole GFCI will work fine. The key is that all the current leaving and returning is through the three conductors.
Roger
Just a question, why do you feel that adding another circuit run out to the pool would make it necessary to add a ground rod? You're not adding a second panel, or are you thinking that you need to do that?
I don’t think the code allows more than one circuit to a separate structure without adding the rods. I think having two circuits would require I install a subpanel that would need the electrode.
Roger
Thanks. My first thought was that the current on both legs would have to be balanced. After thinking about I figured it was more about having no current flowing on the egc.
That's true but for a 3-wire MWBC (2-120 volt circuits) to a separate structure that can be considered one circuit.
Please see definition of Branch Circuit, Multiwire, and 250.32 (A)
Looks like Infinity beat me to this
