knoppdude
- Sacramento,ca
I wired double duplex receptacles in a small laboratory with another electrician, with each receptacle having one ungrounded conductor, and a common neutral with the other. I know that 210.4(B) states that the use of a two pole breaker, or two breakers with a handle tie are only required if the circuit(s) terminate on a device on one yolk, but is it necessary to use a common trip breaker in a situation where a multiwire branch circuit terminates to two separate receptacles in a common junction box? HOpe this question is not too mundane. Thanks.
