howardrichman
I'm wiring a 120V septic pump conduits into panel room, and bringing in the low V alarm wiring isolated. I need an outlet for the alarm, and considered a 3 wire multi circuit feeding thru j-box for the pump, and other for the outlet from a close by panel. I know normally I'de need a 2 pole breaker or 2 breaker tye handled, but obviously I cant have the outlet for the alarm go out w/ the pump if a short circuit occurs. Is the only way to do the extra work to install a separate outlet for the alarm?
HR...
HR...
