Just trying to fully understand what I think I allready know. In a muiltiwire circuit, if phase A is pulling 5 amps and phase B is pulling 8 amps then the neutral current will have 3 amps on it. If in a multiwire circuit you are shareing a neutral with two circuits on the same phase, the current adds. For example, if phase A is pulling 10 amps and phase A is pulling 10 amps your neutral current will have 20 amps on it. If a single branch circuit with its own neutral is pulling 10 amps then the neutral current will have 10 amps. Is this all correct.
