James L
- Kansas Cty, Mo, USA
- Electrician
I wired a Murphy door yesterday. It's a "hidden door" bookcase door with magnetic catch. It has 2 buttons, one outside the room (in the bookcase) and one inside on the wall. The two buttons are 2 feet apart, so I ran one 18/2 cable to the door jamb and split (option #1 in the diagram)
After I powered it up, I tested from the inside button and it worked. So I packed up all my things to go, then had a thought to check the other button. Now it doesn't work at all, even from the inside button.
120 volts is good.
No power at "C + NC"
No power at "C + 12v"
GC chatted with door manufacturer, and they asked if I tried wiring option #2 - no, I didn't.
They're saying if I rewire to option #2 that usually fixes the problem. I'm saying that makes no sense. If power in is good, but there's no power out on either the feed-thru or the relay output, rewiring won't help.
But I'm sure the whole box is full of electronics, which just might be my weakest skill set.
Any thoughts?
120 volts is good.
Any thoughts?
