Has anyone here ever had to remove, relocate and reinstall musco tennis court lighting poles? We were thinking the best way would be to either weld a support on the side of the pole and use hydraulic jacks to move the steel pole up so a crane could lift it or fabricate a clamp brace which would bolt around the concrete base and use it to jack up the steel pole. The method with welding may be out as they may not want any marking on the steel poles.
