jcook980
- Gresham, Oregon
- Electrical Engineer
Musicians sometimes have a great deal of audible hum generated by ground loops caused by the signal connections between their instruments and signal processors like amplifiers and mixing boards. Many (far too many...) musicians carry 2-to-3 prong adapters with them to gigs to lift the mains ground to their instruments. In most cases, this cures the hum but obviously eliminates an important electrical safety feature.
It would seem to me, that a far better solution would be to use a portable GFCI adapter. But, every one I've seen apparently carries the ground through the adapter since they all have 3-pin plugs. A kludgy way to do this would be to use the 2-to-3 adapter to lift the ground and plug the portable GFCI adapter into that. What's really needed is a NRTL listed portable 2-pin to 3-pin GFCI device.
Now I know that many will recoil in horror at this idea. As an electrical PE, I don't like it either. But the bad practice of lifting the mains ground is going to continue and musicians are going to continue to get injured and killed when an internal fault occurs. Surely the GFCI will restore some of the protection offered by the mains ground.
Comments or other ideas?
