The background of my question is from an offshore industrial (IEC) perspective, but I welcome feedback based on commercial and/or NEC/ANSI/NEMA design.
In order to remove the shock hazard for people present in a space where a fire starts and activates the water-based fire protection (water mist or sprinkler/deluge): is the fire (& gas) system typically designed to automatically trip all breakers which are feeding power to equipment in that space? If so, does that include de-energizing receptacles, light fixtures, etc., which would also pose a hazard (unless they have suitable IP rating to remain energized)?
We're evaluating different types of fire suppression (e.g. watermist, gaseous, etc.) for an emergency switchgear/generator room, as well as proper IP rating of the switchgear. There's a push to go with watermist due to lower cost, but our switchgear Mfr has not tested the equipment (IP42) with mist, only dripping water. Hence, I'm concerned that the mist will maneuver into the gear in a way that could cause unintended components to become energized. I realize this is why we bond/earth, but trying to understand whether this is a credible concern (e.g. if the switchgear is disconnected via the FGS system upon fire detection, the hazard is removed, so IP rating isn't an issue).
