I’m hoping someone can offer a solution to a MV cable routing problem.
We have two structures that will experience a maximum differential seismic movement of 15” (9” north-south, 12” east-west). No vertical movement. 4” conduits pass from one structure to the other. We were considering a loop of flex conduit, but using the minimum bend radius of 24” (NEC Chapter 9, Table 2), the length of flexible conduit required is around 6.5 to 7 feet to create the loop, and 348.30 (A) Exception No. 2 (3) allows only up to 5 ft of unsupported/securely fastened flexible conduit.
This solution will not work if the flexible conduit has to be securely fastened anywhere along its length.
We don’t want to transition to jacketed MV cable, and placing the flexible conduits on a flat tray (loop would lay horizontally) would support the flex, but it would not be fastened.
Any help on this matter would be greatly appreciated.
Patrick
Patrick
