We are looking at a project that is considering running 4.16kV cable in a single underground PVC pipe without a concrete encased ductbank. I am used to seeing PVC conduits run in concrete encased ductbank however that does not appear to be a requirement but rather perhaps a good practice in some applications.
This application is simply running a cable between an existing pad mounted transformer and an skid located across an open field so there doesn't really seem to be a necessity for concrete encased ductbank.
Per 300.50 it appears that at 4.16kV the PVC conduit would be required to be 18" below grade. I'm curious is this is simply putting in a PVC pipe and backfilling with soil or if there is a typical backfill or other details that are typically used specified.
If anyone has any comment, suggestions, or a typical detail it would be much appreciated.
