mstrlucky74
- NJ
What do you guys think about this setup/cable pull? Is it a good idea to have the reels on the trucks like that. Actually bidding a similar situation where where are pulling 3#500 MV cables into a 4" duct bank?
If you have a 400' run of existing conduit with a manhole in the middle of the run would I assume you would pull all the way through....setting up the reels at one end and the tugger at the other??? If you had a 90 degree turn at the manhole in the run how would you guide the cables to make that turn in the mahole? Thanks.
https://www.youtube.com/watch?v=N_yXgo7WjoE
