MV Delta Connected/Ungrounded Switchgear Protection
kingpb
SE USA as far as you can go
Engineer, Registered
I've been looking at protection for MV switchgear (13.8kV) where the switchgear is ungrounded. In a nutshell; it is to avoid transfer of harmonics onto the utility side through the transformer, which is delta connected on the MV side.
We can add a zigzag transformer to create a ground on the MV bus, or utilize a relays, such as the SEL 351A with the optional Sensitive Earth Fault Function.
The 351A on the main would indicate a GF on the bus, but would not indicate which feeder, (28 Feeders). I would think it preferable to be able to isolate the feeder. Placing a 351A on each feeder is not out of the question other than it adds about $400 (x28) to the cost of the relay, (551C vs 351A).
Would be interested in feedback from others on how to address this issue in the most cost effective manner.
