I am working on a job where a cogen facility is being upgraded with two (2) new turbine generators. Each one will have a feeder from a 1200A circuit breaker to a substation some 2500 feet away. We will be installing two (2) 3C-500 kcmil cables along side four (4) existing 3C-500 kcmil cables in a cable tray so that each feeder will consist of three (3) sets 3C-500. Currently a bare copper ground conductor (not sure if it's 2/0 or 3/0) is run in the tray with the four (4) existing feeder cables. We are being asked to install an additional grounding conductor (3/0) in the tray because the "ampacity of the tray" has increased. I'm not sure that a second conductor is warranted, but I don't know how to research this. Can you give me any suggestions?
