mstrlucky74
- NJ
When running single conductor 15kv wire is the ground always 600v? Thanks.
Hmmm... not sure what you mean. Ground is ground. Are you asking if the grounding conductor can be insulated and can that insulation be rated at only 600V?
My guess is that grounding conductor could be bare in most instances.I guess??:? I just remember often seeing something like 3 #1/0(15kv) and 1 600v ground in past feeder schedules. Now I've come across 3#1/0 and 1 #1/0 ground but it doesn't say 600v for the ground
