Minimum LV cable sizing based terminal temperature is very straight forward based on NEC 2023 article 110.14. Basically, select the cable ampacity based on the terminal temperature rating utilizing Table 310.16 (either 60C or 75C depending on the equipment terminal rating). I understand that there is a second test (conditions of use) but I am not concerned with that completely separate issue. I only want to focus on the first test. A similar approach is provided by NEC 2023 article 110.40 for MV cables. However, this section provides cable ampacities based a Tables 315.60(C)(1) through 315.60(C)(20). My question is which table do you utilized. Inside the termination box, the cable should be treated as single conductor in air in my humble opinion, but I am sure this is will not be the forum consensus. NEC 110.14 basically only let's you select the cable ampacity based on Table 310.16 and purposely excludes 310.17 (which has higher ampacities). From a logic standpoint, I guess you would select the cable ampacity based on the worst-case cable configuration.
