mjf
is it true that GE makes an arc-fault breaker for MWBC's?
is it a 2 pole breaker or can I use 2 single pole breakers with a handle tie?
You can use two single pole breakers with a handle tie. It's a weird set up, you still run the neutral to one of the single pole breakers. I have never used one, just heard about them. Google up GE MOD 3.is it a 2 pole breaker or can I use 2 single pole breakers with a handle tie?
