wwhitney
- Berkeley, CA
- Retired
That also applies to wiring methods with a nonmagnetic sheath. Presumably that covers aluminum clad multiconductor MC cable and aluminum EMT. But then does the NEC require you to use nonmagnetic fittings? Or are most fittings zinc or pot-metal, so they would be nonmagnetic anyway?The only requirement for for a non-metallic wiring method is that the ends of multiple cables or raceways used for a single circuit comply with 300.20.
Cheers, Wayne
