PetrosA
- Lancaster, Pennsylvania
Hi all! I've been reading for some time, but this is my first question to you.
I'm working on a job now wiring what will be a 4000 sq. ft. lighting showroom. The service is 3-phase 208V wye. There will be both plug strips (not the wiremold kind, but one designed for lighting displays) and clouds. Needless to say, there are circuit requirements out the wazoo in this place.
Most of my experience has been with residential single phase, hence this question: When running MWBCs in a 3-phase system, is it acceptable to run a common neutral to only two of the phases instead of all three? The reasoning behind the idea is so that the lighting display circuits can be controlled more precisely (two circuits shut off at the panel instead of three). I haven't been able to find enough information about phase canceling in 3-phase systems to answer this myself.
Thanks in advance,
Peter
Thanks in advance,
Peter
