hurk27
- Portage, Indiana NEC: 2008
Ok well maybe not the church but it is the Rectory
I figured since others have posted there incriminating photo's, I guess I should too.:roll:
This House (rectory) was originally fed from the main service in the church, about 15 years ago, the feeder was damaged by a tent stake driven in to the black top (parking lot) when they were putting up tents for a festival they hold every summer, the RMC and feeder was abandoned, and a temporary feed 3-#2cu, was ran to the maintenance building which has 400 amp feeders run from the church service MDP to a disconnect on the out side of the maintenance building, the maintenance building doesn't use but enough power to light a small office (1 light and 2 receptacles) and two 70w wall packs, the house which was all gas heat and appliances never had a problem on this temp. feeder until a couple years ago, when the kitchen was remodeled and a double oven and cook top was added, I was called because of the lights dimming but they didn't have the money to replace the feeder, so I adapted the fuses to 100 amp to at least protect these undersized conductors at the garage, and they ran on these temporary feeders till now. well a new Father is in place and he wants a hot tub for a back problem, whoops, I was called in and had to tell him there was no way it was going to run off this panel in the house unless the feeders were replaced. well to make it short, today, I trenched 355' installed new 4/0, 4/0, 2/0 Al. feeders, no spaces left in th existing panel, so I installed a new 30/40 circuit panel, and temped it to the existing feeders, tomorrow I will change it over to the new feeders and install the 200 amp fuses back in the disco at the maintenance garage.
After reviewing my photo's I found two biggie mistakes:roll:
lets see if someone else spots it. Hint: look in the before and after photo's
The photos are in this order, original panel, cover, and insides of panel, trench after new feeders ran, the tear out, and install of the new panel, and after the wires and breakers are installed, in the photo of the maintenance garage if you zoom in you can see the disco on the side of it, that I had to run from:roll:
Not done yet, have to go back tomorrow and fix two boo boo's
and switch the panel to the new feeder.:roll:
Guess I have to make a second post for the rest of the photos
so wait there coming
