hotblueelectric
- Dallas Texas
1. Im installing a 320 amp meter base feeding 2 exterior 200 amp circuit breaker disconnects, feeding 2 200 amp interior panels.
2. I’m running a #6 bare from CB #1 to ground rod #1, then on to ground rod #2, then to CB #2.
3. Both CB’s disconnects bonded.
4. Im running a #6 stranded from each (non bonded, ground and neutral separate) sub panel to each CB.
5. I’m running an un broken #6 stranded from each CB to the rebar. ( does this #6 need to be un broken? Code reference?)
Does this look correct? Am I missing something? Your advise is greatly appreciated.
