Alwayslearningelec
- NJ
- Estimator
I don't know if this is the place but maybe I can get some advice. I put in two piers at the end of my driveway that will have lights in them. They will be fed from the panel in my garage. Then one side is fine as I can run it down the bed right along the driveway and into the garage. The one on the other side is a problem as I have to get across the driveway and lawn( which is only about 10x15). Someone mentioned there is something that "shoots" under the ground that will(i guess) help run the pipe. I don't know how to get this pipe to the garage panel which about 40' away depending on path taken.
Thanks very much.
Thanks very much.
