Elec_1
- Mayodan,N.C.
I have a older building my medium voltage comes in on the left compartment stepdown transformer in the center compartment and the mdp in the right compartment.I am suppose to have 12470 in and 480 out(no tap adjustments on the 480 side) my measured 3 phase voltage is 505 phase to ground I believe I measured 291. My receptacles are like 121ac. I have had the hvac shop install a new unit for a students computer lab. The HVAC compressor unit aparently has pt on it so when it sees the voltage hit say 506 the pt cut the compressor out.I need a economical way to cut my power back just on this one air handling unit Iis rated 16.8 ampr rla and the fan.8amps fla. my They are using a 3 phase disconnect with 30 amp fuses in it. I need a economical way to get my voltage cut back to 480 volts on this piece of equipment, and when I ask my supply houses for help they are bewildered.
