Nils
New User
- Connecticut
- Electrician/Field Manager
Hello, I am dealing with a Solar project to where the specs and design call for outdoor NEMA 4X enclosures having conduits entering on the bottom to use a combination of a Myers Hub AND and LFMC connector assembly for flexible conduits. The issue I am having is the the tapered internal threads of the Myers Hub and the threads of the LFMC connector are more than 5 fully engaged and are watertight, however the yellow sealing gaskets of the LFMC connector are loose. The LFMC connector is as tight into the Myers hub as possible, our installer used a RIDGID tristand chain vise and a pipe wrench to ensure the maximum threads possible are engaged without damaging the assembly. However, we have a round a 5/16” gap of threads between the Myers Hub and LFMC connector, causing the 1/8” yellow sealing gaskets from the LFMC connector to be visibly loose. The local AHJ and a 3rd Party Mechanical Completion Inspector have passed the assembly as is, stating that the gaskets are now redundant and not necessary due to the fully engaged threads of this particular assembly. We even had a “WET TEST”, where every inch of our system was thoroughly soaked with a water based solution, and then tested for short and inspected for moisture intrusion. We passed this test 100% and every enclosure on site was bone dry.
Now here is our problem, I have a 3rd Party Commissioning Agent with absolutely no field experience and very little understanding of the NEC basically telling me “it doesn’t look like the picture in my book” regarding the loose yellow sealing gaskets. Of course the picture he is using does not have a Myers Hub in it, the LFMC connector in that photo is fully seated directly to the enclosure with a tight yellow gasket. Once it was explained to him, his response was “I don’t care”
Does anyone here know of any aesthetic quick fixes for this situation. We are not going to cut and remove the gaskets, we are passed that now, and we are trying to avoid un-terminating cables and pulling the cable back through to replace the existing gaskets with thicker gaskets. Does any one know of any type of external weatherproof collar of something like that that may suffice once presented as a solution. This one silly issue is holding up COD on the project. Any assistance possible here would be greatly appreciated.
Thank you,
Thank you,
