silverromex
This has remained a mystery to after 3 years. I use to work for a company 3 years ago that would send me on service calls even though I was unlicensed and had only 1 year of experience. This 1 call I was sent on involved maybe 12 H.I.D. lights in a wharehouse that were tripping a 3 pole, 20A, 120/208V breaker. The breaker fed 3 rows of lights with phases A-B down row 1, A-C down row 2, and B-C down row 3. I think the amp readings per phase were close to 25 amps, whatever they were I remember the breaker would trip after about 5 minutes. What my boss had me do to fix the problem was run a 3rd wire down each row from the phase that wasn't being used in that particular row of lights , so the row using phase A-B now had a C phase wire installed but it wasn't connected to anything. This did correct the problem because when I finished installing the 3rd wire down each row of lights the breaker finally held and the amps dropped down to something like 15 per phase. My question is was this installation code compliant and what caused this to lower the amps just by adding the 3rd wire that didn't connect to anything, something to do with inductance or magnetism? Thanks.
