Called In To Place Countertop Gfci Receptacles In Single Family Residence Built And Wired About 1954, S.E. Panel Is All Edison Fuses,
100 Amp 240/120 Volt. The Big Mystery Is An Independantly Energized
No.12 Red Wire To All The Kitchen Outlets In Addition To The Normal
Black No. 12. The White No.12 Grounded Neutral Seems Ok. These Outlets Are Not Switched. Disconnecting The Red No.12 From One Outlet Causes The Other Outlet To Go "open Ground". Hot Red And Hot Black Are On The Same Fuse.the Gfci's Are On Hold Until This Mystery Is Solved. Anyone See Anything Like This From The 1950's,?
