- Tennessee NEC:2017
- Semi-Retired Electrician
I had a service call to check some switches & lights in a bathroom. The bath has a 3G box with three SP switches. There are three lights, one over the tub, one over the vanity, and one over the stand-alone shower. The HO say/swear that each switch used to operate one light. I never saw this but pretty sure they were telling the truth.
So now, when you turn on either of the first two switches, both the tub & vanity light come on. The shower light still works as it should.
I took the plate off the switches and checked the wiring. All is correct in the box.
Hot comes in on a 12-2 NM cable
Each switch has a pigtail to the hot
Each switch has a 12-2 feed out to the lights
So (4) NM cables in the box total
I removed the feed wires off the two switches that were both working the same two lights. There is continuity between the two wires, thus why both lights work from either switch. I took the neutrals apart and checked them but found no continuity between them.
Further info: the house is a log house so I couldn't look in the ceiling or walls. Also the lights are can lights and I couldn't get to the wiring there either.
I have a theory (actually two) about what is causing this. But I wanted to hear other opinions to see if what I'm thinking is correct. Anyone care to comment on this?
