N.E.C. requirement
Re: N.E.C. requirement
No requirement for the fan.
If your talking about a light on the fan that would depend f that was the only lighting fixture in the room.
There must be a switched lighting outlet (yikes!) in the room, which can be either a fixed luminaire or a switched receptacle.
If you mean that a pull-chain-operated fan was added to a room with a switched receptacle, then no, you do not have to rewire.
"And if that fan is in a bedroom must be on afci circuit"
Unless you are in Indiana where only the receptacle outlets in a bedroom are required to be AFCI protected.
Don`t let al see switch in the same post as afci.Jeff see what you have done.Gun shy about 2 simple words. :D
