I see a lot of standard nail on boxes used for portable storage sheds, in attic spaces, unfinished garages, and the like, where they used NMB for the wiring that never will get a finish such as sheet rock or any other covering put on the face of the studs.
Is there any issues using this type of box for this?
Standard plastic plates installed on devices mounted to nail on boxes that don't have a finish flush with the front of the box has never looked right to me, nor, does the opening where the NM pushes into the plastic box that doesn't actually seal around the cable.
When these boxes are installed in a wall with insulation around them and then sheetrock installed on the face of the studs, there's not much chance of anything foreign getting inside the box, which is not the case if these boxes are used where a wall covering is never installed.
Just curious.
JAP>
Just curious.
JAP>
