The bonding grid in a substation is typically used in the types of substations that have exposed medium voltage conductors and equipment, not where a fully enclosed pad mount type transformer is installed.Thanks for the replies.
I think it has been stated on this forum that substations require equipotentail bonding, and an equipotential ground plane. Where do those requirements come from if not from the NESC?
And why do utility substations require this grounding and bonding when typical utility pad mounted transformers do not?
Also wondering how this would apply to a factory substation that is installed in a penthouse and not on the ground.
